bobby_k's avatar
bobby_k
Netgear GS110TPv3 SNMP
With the older GS110TP switches it was possible to update the firmware on the switches using SNMP. Using the ng_switching MIB I believe.
The new GS110TPv3 doesn't seem to support this functionality. Is it actually possible, or will the functionality be added in the future?
Thanks.
    • bobby_k's avatar
      bobby_k
      Thanks for the reply. I have downloaded the MIBs for the GS110TPv3, but unlike earlier switch versions that set of MIBs doesn't include ng_switching, which is where the controls for firmware updates were found. Scanning through the other MIBs in there I don't see any options for firmware options.
      • schumaku's avatar
        schumaku
        Not sure Netgear does continue to implement the proprietary enterprise MIBs .1.3.6.1.4.1.4526 on the newer switch models.
        YeZ please.
ProSupport for Business
