PFelen
Apr 30, 2022Aspirant
Netgear GS324TP switch has connection issues while Netgear GS716Tv2 has not with same devices
Hi Netgear Community, Last year I bought a Netgear GS324TP switch (serial number: 5LFxxxxxxxxx, firmware version: GS324Tx-v1.0.0.38) to replace my Netgear GS716Tv2 switch (serial number: 23Yxxxxxxxx...
DaneA
May 04, 2022NETGEAR Employee Retired
Welcome to the community! 🙂
Are there VLANs configured on the GS324TP or are you just using it like an unmanaged switch? If your are just using it like an unmanaged switch, I suggest you to perform a factory reset on it then observe if the same problem will occur.
DaneA
NETGEAR Community Team
PFelen
May 09, 2022Aspirant
At this moment it is configured as an unmanaged switch. Intention is to start using more functions, but then the basics need to work flawlessly without issues first.
I tested the factory reset sugestion, but that makes no difference. Same issues as before.
GS324TP S350 reports cable issues and to some devices I can't connect, while the good old GS716Tv2 has no problem of any kind with the same cables and devices.
Any clues, or should I exchange my device for a new one?
- Aug 17, 2017Retired_Member
