Anonymous's avatar
Anonymous
Aug 17, 2017
GS716Tv2 suddenly Link Down
I have a GS716Tv2 which after a few hours shutsdowns some links. The link won't work anymore even after a powercycle the link stays down. Only after loading factory defaults the link is up again...
What's wrong? Why is the link suddenly down? And how can I solve this problem?
  • DaneA's avatar
    DaneA
    Sep 04, 2017
    Retired_Member,
    I just want to follow-up.  Any updates on the status of your GS716Tv2 switch?
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi Jeroenst,
    Welcome to the community! :)
    Let us isolate the problem.  Kindly answer the questions below:
    a. Was everything working fine before?
    b. Are there any recent changes made in the settings of the GS716Tv2 switch or changes made within your network setup?
    c. Have you tried changing the ethernet cables on the links that shuts down on the GS716Tv2 switch?
    d. How is everything connected?  It would be best if you post a diagram of your detailed network setup.
    e. What is the current firmware version of your GS716Tv2 switch?
    DaneA
    • DaneA's avatar
      DaneA
      Retired_Member,
      I just want to follow-up on this.  We’d greatly appreciate your feedback.
      DaneA
      • Anonymous's avatar
        Anonymous
        After loading factory defaults and not enabling powersavings the switch keeps functioning fine. Next step is to enable powersavings again.
        I'll let you know the results.
      Anonymous
      Dear DaneA,
      A. Do not know, i just got this switch
      B. No
      C. Yes, interface stays down, only loading factory defaults makes the port working again.
      D. Point to point, nothing special.
      E.
      Model Name GS716Tv2
      Boot Version B5.1.1.1
      Software Version 5.4.2.30
        Anonymous
        The switch is now still working with eco modus enabled...
ProSupport for Business
