Retired_Member
Aug 17, 2017GS716Tv2 suddenly Link Down
I have a GS716Tv2 which after a few hours shutsdowns some links. The link won't work anymore even after a powercycle the link stays down. Only after loading factory defaults the link is up again... ...
- Sep 04, 2017
Retired_Member,
I just want to follow-up. Any updates on the status of your GS716Tv2 switch?
DaneA
NETGEAR Community Team
DaneA
Aug 20, 2017NETGEAR Employee Retired
Hi Jeroenst,
Welcome to the community! :)
Let us isolate the problem. Kindly answer the questions below:
a. Was everything working fine before?
b. Are there any recent changes made in the settings of the GS716Tv2 switch or changes made within your network setup?
c. Have you tried changing the ethernet cables on the links that shuts down on the GS716Tv2 switch?
d. How is everything connected? It would be best if you post a diagram of your detailed network setup.
e. What is the current firmware version of your GS716Tv2 switch?
DaneA
Retired_Member
Aug 29, 2017Dear DaneA,
A. Do not know, i just got this switch
B. No
C. Yes, interface stays down, only loading factory defaults makes the port working again.
D. Point to point, nothing special.
E.
Model Name GS716Tv2
Boot Version B5.1.1.1
Software Version 5.4.2.30
B. No
E.
Model Name GS716Tv2
- Retired_MemberAug 29, 2017The switch is now still working with eco modus enabled...
