Retired_Member
Aug 17, 2017GS716Tv2 suddenly Link Down
I have a GS716Tv2 which after a few hours shutsdowns some links. The link won't work anymore even after a powercycle the link stays down. Only after loading factory defaults the link is up again... ...
- Sep 04, 2017
Retired_Member,
I just want to follow-up. Any updates on the status of your GS716Tv2 switch?
DaneA
NETGEAR Community Team
DaneA
Aug 23, 2017NETGEAR Employee Retired
Retired_Member,
I just want to follow-up on this. We’d greatly appreciate your feedback.
DaneA
Retired_Member
Aug 25, 2017After loading factory defaults and not enabling powersavings the switch keeps functioning fine. Next step is to enable powersavings again.
I'll let you know the results.
