falafell42
Nov 28, 2020Aspirant
netgear gs724t poe injector
I have a netgear gs724t and am trying to use poe injectors. Whenever I use them on the switch every port negotiates down to 100mb regardless of what i set. Do i need specific voltage injectors? Doe...
Nov 28, 2020Guru - Experienced User
are you going:
router/data connection------>switch-------->poe injector------->device needing poe?
falafell42
Yes.
Exactly that.
Internet connection-> injector. -> Unify AP
Exactly that.
- falafell42Nov 28, 2020AspirantApologies
Switch -> injector -> unify AP- schumakuNov 28, 2020Guru - Experienced User
Exact make and model of a power injector.
Well possible some injectors are not designed to passthrough all four pairs required for Gigabit Ethernet.
Nothing the switch or switch admin can do here.
