Willosy
Jan 09, 2019Aspirant
Netgear GS748Tv4 Fan Failure - Replace fan or Switch?
Hi community,
First time posting here, so be nice :)
A fan or two has failed in my switch and I was wondering if a mod or similar could let me know fan specs so I can find a replacement. ...
- Jan 21, 2019
I inquired your concern to the higher tier of NETGEAR Support. As per the higher tier of NETGEAR Support, here below are the following fan specifications of the GS748Tv4 switch:
- 10500 rpm Max speed.
- The max air flow is 14.5CFM and the Max static air pressure is 0.71 inH2O(18.0mmH2O).
- The maximum noise level is 44dBA.
- 40X40X20mm
- 3pin
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
Willosy
Jan 10, 2019Aspirant
Hi Dane,
I've just pm'd you, sorry, no longer have the sales receipt as I've moved house.
Cheers Willo
Cheers Willo
Willosy
Can I please have the fan specs?
- DaneAJan 10, 2019NETGEAR Employee Retired
Let me share these links below and it might help:
NETGEAR GS748T/GS724T Switch Loud Fan Swap Modification
NETGEAR GS748T Switch Loud Fan Swap with Quiet Fan
NETGEAR GS724T Switch Fan Replacement
Netgear GS748Tv4 Fan Failure - Replacement Fans not working
Regards
DaneA
- WillosyJan 10, 2019AspirantThanks again.
I've seen all of those links but wanted to find my own fan because the retail pc the fans need messing with to mount or aren't 100% compatible with the switch e.g. still report fan failure.
If I know the specs of the fan as requested I can get something that slots straight in.
I don't have the time to keep pulling the switch in and out to get an outcome.
You're help is appreciated.- DaneAJan 21, 2019NETGEAR Employee Retired
- 40X40X20mm
- 3pin
DaneA
