Willosy
Jan 09, 2019Aspirant
Netgear GS748Tv4 Fan Failure - Replace fan or Switch?
Hi community,
First time posting here, so be nice :)
A fan or two has failed in my switch and I was wondering if a mod or similar could let me know fan specs so I can find a replacement. ...
- Jan 21, 2019
I inquired your concern to the higher tier of NETGEAR Support. As per the higher tier of NETGEAR Support, here below are the following fan specifications of the GS748Tv4 switch:
- 10500 rpm Max speed.
- The max air flow is 14.5CFM and the Max static air pressure is 0.71 inH2O(18.0mmH2O).
- The maximum noise level is 44dBA.
- 40X40X20mm
- 3pin
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
