RMcEwan17
Jun 28, 2021Aspirant
Netgear Insight - Denial of Services settings??
We have lot of switches connected to Insight and its great but on one switch we have a port that keeps disabling itself due to CRC Error packets.
We need this port to stay enabled and from what ive read it is caused by Auto DOS or Denial of Service settings??
I can't see these settings within the insight portal, can anyone help me find them?
Br rule of thumb, the DoS settings are not covered by Insight.
Check if the DoS controls are available on the local WebUI.
In case these are not accessible, you mght have to bring the switch to local management mode, change the DoS config, and re-add to Insight.
- RMcEwan17Aspirant
Thanks for the fast response, I was hoping to avoid that but if thats my only option i can go and try it.
I wasn't sure if re-adding it to Insight would wipe my changes if it didn't allow it within insight. I'll try visit the site in the next few days and let you know.
