S_Cook_1
Dec 07, 2022Follower
Netgear JGS516PE updating firmware
I'm connecting to a remote Netgear JGS516PE switch and have attempted to update its firmware to 2.6.0.48 I navigated to Maintenance > Firmware Upgrade and uploaded the firmware. The file uplo...
DaneA
Dec 07, 2022NETGEAR Employee Retired
Welcome to the community! 🙂
Kindly try to use Incognito mode in Chrome or try using other browsers like Firefox and check if you will be able to access the web-GUI.
Try to reboot the JGS516PE as well then check again if you will be able to access the web-GUI.
If my suggestions above did not work, I advise you to perform a factory reset on the JGS516PE then check again if you will be able to access the web-GUI.
DaneA
NETGEAR Community Team
