brandon16
Sep 20, 2016Aspirant
NETGEAR ProSAFE GS752TP
i have two NETGEAR ProSAFE GS752TP and i want to stack them. what would i need to stack them
- Sep 20, 2016
Hi brandon16,
You may want to configure LAG on your two GS752TP switches. Kindly access and read the article below for reference:
What are Link Aggregation Groups (LAGs) and how do they work with my managed switch?
DaneA
NETGEAR Community Team
brandon16
Thanks for the fast reply. I should of bought GS752TPS but I bought GS752TP :( I will have to figure something out on connecting this two together or might have to have them run independant
DaneA
Sep 21, 2016NETGEAR Employee Retired
Hi brandon16,
Use the article below as a guide in setting up VLANs and VLAN Routing on your GS752TP:
VLAN Routing on New Smart Switches
DaneA
