mparikh
Jun 23, 2017Aspirant
Netgear ProSafe JGS524Ev2 - IP/MAC Address Table
Hello Everyone, Model: JGS524Ev2 Firmware: 2.0.1.40 Utility: ver 2.4.3 OS: Windows 7 My name is Meet Parikh and I'm an Electrical Engineering at CTDI in West Chester PA. Now I just joined...
- Jun 25, 2017
Hi Mparikh
The Switches that support VLAN, Telnet, SNMP,SSH,CLI are our Fully Managed switches , see below a a link with all our fully managed families:
https://www.netgear.com/business/products/switches/managed/
About the IP/MAC/Port Address you will have to combine a sh arp and sh mac-addr-table to be able to get the IP/MAC/Port
Regards
Xavier Lleixa
NETGEAR CBU PLM
XavierLL
Jun 23, 2017NETGEAR Employee Retired
Hi mparikh
Welcome to our community!
Unfortunately the JGS524E doesn't support SSH/SNMP or CLI so in this case you will not be able to get the MAC address table from the switch.
I would suggest to use our M4100 switch series where we support SSH and SNMP and you can send commands to get the MAC address table
https://www.netgear.com/business/products/switches/managed/M4100-26G.aspx#tab-techspecs
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
mparikh
Does JGS524Ev2 have VLAN capabilities, or what switch would you recommend for both telnet/SNMP/SSH and VLAN capabilities.
Thank You,
Meet Parikh
- mparikhJun 23, 2017Aspirant
I meant to ask you the following question in the previous reply post:
What switches does Netgear have with VLAN capability in addition to remote control (Telnet, SNMP, SSH, CLI) to enable/disable ports and get IP Address of devices connected to the ports?
Thank You,
Meet Parikh
- XavierLLJun 25, 2017NETGEAR Employee Retired
Hi Mparikh
Regards
Xavier Lleixa
NETGEAR CBU PLM
