odessouky
Nov 05, 2020Aspirant
Netgear Prosafe XS712T stock fan replacement?
I have setup a 10GbE home network/lab, and my backbone is the XS712T. Not the version 2, but the older model. Its used and possibly out of warranty. The fans on my 10GbE Netgear Prosafe XS712T sw...
schumaku
Nov 05, 2020Guru - Experienced User
Difference does indicate lower high RPM and much lower airflow overall. The original fan can use up to 8.7W, while the alternate low noise one runs on .7W. That makes it easy to be much more silent.
I must admit that fans - especially with a lot of operation time at potentially higher RPMs are wearing out, starting to cause more noise than required.
