daniel-germany
Oct 29, 2018Aspirant
network slow: 3 switches between router and pc
Hi,
i have a network that distributes an internet connection (1gbit) to 17 house staircases over copper with 6 endpoints each, so that at each endpoint a maximum of 32MBit up/down can be used a...
- Dec 05, 2018
The length of the cables and amount of switches caused packet collisions.
The problem was solved by inserting routers.
Now everything is running fine.The problem was found that way:
https://blog.mameso.com/2018/11/analyze-packet-loss-with-wireshark/
best regards,
daniel
daniel-germany
Nov 04, 2018Aspirant
looks like i can not extend the 100m limit with switches.
so i need to use fibre for the 2 long distances (90m and 170m) or replace this two GS110tp Switches with routers.
schumaku
Nov 04, 2018Guru - Experienced User
Well, a router might help to drive another media type - but probably not in this case, unless you are going to use some other technology for the longer distance.
Better approach would be to migrate the longer distance links to some inexpensive fiber some Multi Mode Fiber does drive GbE over up to 1000 meters or 10GbE on up to 550 meters.
- daniel-germanyDec 05, 2018Aspirant
best regards,
daniel
