clarens2253
Jan 20, 2021Aspirant
NMS300 1.7.0.1
Hi. NMS300 1.7.0.1 + 3x GS748Tv5 FW: 6.3.1.36 + GS724Tv4 FW: 6.3.1.36. Backup of SW configuration not working, passwords are correct. I got errors:
DaneA
Jan 21, 2021NETGEAR Employee Retired
On what Operating System is the NMS300 installed?
Did you just newly update the NMS300 to v1.7.0.1? If yes, is everything working fine before you did the update?
DaneA
NETGEAR Community Team
- clarens2253Jan 21, 2021Aspirant
NMS 1.6.0.27 same situation. I think the problem is in firmware 6.3.1.36
- DaneAJan 24, 2021NETGEAR Employee Retired
Let's try this. Kindly try to uninstall then reinstall the NMS300 in your PC. Then, check if the same problem will occur.
If ever the same problem occurred, I suggest you to open a support ticket with NETGEAR Support here at anytime for further investigation.
DaneA
- clarens2253Jan 24, 2021Aspirant
Windows 2012 R2 Foundation. Reinstallation didn't worked. Support contacted.
