virtualnobody's avatar
Dec 01, 2015
NMS300 and S3300
Dear Community,
I have installed NMS300 (latest) and discovered some devices, also created new device credentials. It is working so far except one issue, maybe it is config related.
My S3300-52X-PoE+ is detected in Device Discovery but not added to inventory. Current device status is "Some stack member is empty" stated in NMS Device Discovery Results. Device name, IP address and model is displayed also.
Is it possible to add devices only in "clean" state? It is not mentioned in the manual.
Thanks in advance,
Raphael
  • virtualnobody's avatar
    virtualnobody
    Dec 03, 2015
    Ok, now it works.
    What I have done:
    - Connecting all stack members
    - Started discovery
    Maybe it should be noted in the documentation, the discovered switch must have status "clean" to be added to inventory.
    Thanks for support!
    Best regards.
ProSupport for Business
