virtualnobody
Dec 01, 2015Aspirant
NMS300 and S3300
Dear Community, I have installed NMS300 (latest) and discovered some devices, also created new device credentials. It is working so far except one issue, maybe it is config related. My S3300-...
- Dec 03, 2015
Ok, now it works.
What I have done:
- Connecting all stack members
- Started discovery
Maybe it should be noted in the documentation, the discovered switch must have status "clean" to be added to inventory.
Thanks for support!
Best regards.
virtualnobody
Thanks for your reply!
I did a regular discovery, created a new discovery profile leaving all default values except network type which is set to Single IP matching the switch IP.
Executing this profile leads me to same results, the switch is not shown in inventory.
Adding custom credentials to the profile does not help either. Added HTTP, HTTPS and Telnet credentials (actually HTTP is in use when connecting via webinterface) to the profile but still same result.
Other devices (switches and routers) are discovered the same way and they were placed in inventory.
I will try discovering another S3300-28X-POE+ tomorrow.
Best regards.
virtualnobody
Dec 03, 2015Aspirant
Ok, now it works.
What I have done:
- Started discovery
Thanks for support!
Best regards.
- DaneADec 03, 2015NETGEAR Employee Retired
Hi virtualnobody,
I am glad to know that it works. :) I really appreciate that you have shared what you have done in order to work for the benefit of others here in the community. :)
Feel free to post your future concerns here in the community.
Cheers,
DaneA
NETGEAR Community Team
