clarens2253
Jan 20, 2021Aspirant
NMS300 1.7.0.1
Hi. NMS300 1.7.0.1 + 3x GS748Tv5 FW: 6.3.1.36 + GS724Tv4 FW: 6.3.1.36. Backup of SW configuration not working, passwords are correct. I got errors:
DaneA
Jan 24, 2021NETGEAR Employee Retired
On what Operating System is the NMS300 installed?
Let's try this. Kindly try to uninstall then reinstall the NMS300 in your PC. Then, check if the same problem will occur.
If ever the same problem occurred, I suggest you to open a support ticket with NETGEAR Support here at anytime for further investigation.
DaneA
NETGEAR Community Team
clarens2253
Jan 24, 2021Aspirant
Windows 2012 R2 Foundation. Reinstallation didn't worked. Support contacted.
