tantony
Oct 22, 2018Luminary
No default route on switch
I have a XS716T, and the switch's IP is 172.16.192.2/18. I'm trying to enter a default route to 172.16.192.1, but I'm not able to. I have another Netgear switch (172.16.128.2/18), and it's default route is 172.16.128.1
Why is one switch not accepting default route? I'm not able to manually enter it either.
The XS7xx Default Gateway - which can't be configured from the Routing Table ...
...it does make use of the management IP Configuration default gateway:
- tantonyLuminary
I'm noticing that on the arp cache, it's showing the ip address of the laptop, but not of the switch's default gateway.
I have routing mode enabled, just like on the other switch.
