scm179
May 14, 2021Aspirant
No Internet Access
HI- im no expert here ! been using my switch for a while now for TV , IP Phone printer etc.etc. no problems - purchased new desktop PC and cannot access the Internet ? , i remove the cable which c...
scm179
May 17, 2021Aspirant
Yes i have Ping response from both my Router & Google
DaneA
May 17, 2021NETGEAR Employee Retired
Since you get replies when you ping the IP Address of your router and Google then you should have internet access on your new PC when directly connected to the GS308T.
Try to set Google DNS on your new PC such as 8.8.8.8 and 8.8.4.4. Check if it will let you access any website.
DaneA
NETGEAR Community Team
