GF88
Nov 16, 2025Aspirant
Only the GS308 series loses connection from the Wi-Fi router
When I connect a Sony Wi-Fi router(NSD-G1000T) to Port 1 of a GS308 series switch, it receives an IP address from the DHCP server and functions as a switch for the first 3-5 seconds.
My PC con...
- Nov 18, 2025
schumaku
>Ensure STP (RSTP) et all (like the Loop Prevention) are disabled, and try again.
That (STP) setting (default: ON) was the cause of this issue!
I didn't fully understand STP, so I couldn't fully utilize your comments.Thank you again for following up.
I wanted VLAN functionality, but it seems I was buying a device beyond my level of knowledge. I need to learn more about the device I purchased (GS308T).
schumaku
Nov 17, 2025Guru - Experienced User
A GS308 is an unmanaged switch, nothing to configure.
Or are we facing any kind of GS308E, GS308EP, or GS308EPP?
Unlikely with such a simple config, the Easy Smart Essentials Switches (PoE or not), but also the GS108E the OP is referring to, have a feature called LOOP DETECTION. If in doubt, disable this feature - especially if paired with some more sophisticated Mesh WiFi system, eg. used as a wireless access point.
StephenB wrote:Are you connecting the 2.5 gbps port in the router to the switch?
This has no impact on the switch at least.
GF88
Nov 18, 2025Aspirant
schumaku
Thank you for your advice.
I confirmed the setting of the GS308T.
I had proceeded factory reset at the previous investigation procedures, and the confirmed setting: the loop protection setting was OFF.
I also confirmed the settings of the Sony router, but I could not find sittings regarding these loop protection/detection functions.
I am still having issues, but I appreciate your support.
