GF88's avatar
GF88
Only the GS308 series loses connection from the Wi-Fi router
  When I connect a Sony Wi-Fi router(NSD-G1000T) to Port 1 of a GS308 series switch, it receives an IP address from the DHCP server and functions as a switch for the first 3-5 seconds.  My PC con...
  • GF88's avatar
    GF88
    Nov 18, 2025
    schumaku​
    >Ensure STP (RSTP) et all (like the Loop Prevention) are disabled, and try again.
    That (STP) setting (default: ON) was the cause of this issue!
    I didn't fully understand STP, so I couldn't fully utilize your comments.
    Thank you again for following up.
    I wanted VLAN functionality, but it seems I was buying a device beyond my level of knowledge. I need to learn more about the device I purchased (GS308T).
