TriumphBobber
Mar 30, 2023Aspirant
Orbi RBR750 working with GS716Tv3 working with VLANS
I have an Orbi RBR750 Home system (2 satellites) connected to a Virgin Hub (192.168.0.1) which is set to modem mode. The Orbi acts as a DHCP for my network, 192.168.1.0 mask 255.255.255.0. I ...
- Mar 30, 2023
Ignore me, I now know this won't work and I need a Firewall/Router. I've managed to pick up a secondhand Prosafe Srx5308 Router/Firewall which I know will work as I have the documentation from Netgear on configuring the switch connected to this Router. Thanks again for your help and apologies for getting the solution wrong myself, still learning.
TriumphBobber
Thank you both, thought as much.
If I put a Netgear ProSafe GS105Ev2 5 port switch between the modem and the managed 16 port switch which does support VLANs, and just use the Orbi for the WiFi mesh system as an access point, I think that would work and only cost me about £30?
TriumphBobber
