TierOneTech
Aug 27, 2020Tutor
Phone will not register Cisco 7965G and Netgear GS 752 TPP
Here is my problem. I have added this GS752TPP to an existing Cisco network. Vlan 10 is installed as the native Vlan. Vlan 20 is the voice Vlan. I have half of the switch set as PVID 10 so anythi...
- Sep 14, 2020
So I have finally gotten the phones to work!!
I made sure that LLDP was enabled.
Then I deleted all tagging associated with Vlan 20, which is the Voice Vlan.
I did NOT delete Vlan 20, only any Tagging and Untagging.
Then I went to the Auto-VoIP.
There is a short list of vendors and the first 3 of their MAC's. What I missed before was that I can add MAC's to this list.
So, I deleted most of the existing info and then added the first 3 groups of the MAC's from the phones they want to work through the Netgear switch.
I then enabled Auto-VoIP on all of the interfaces.
By the time I could walk to the phones, they had the correct IP and attached computers had their correct IP!!!
Success!!
Thank you to everyone that contributed!!
DaneA
Sep 03, 2020NETGEAR Employee Retired
Let me share the article below and use it as reference guide:
Let me share the forum link below and this might help as well:
Hope it helps. :)
DaneA
NETGEAR Community Team
TierOneTech
Sep 14, 2020Tutor
Success!!
