JonB16
Sep 08, 2023Aspirant
POE device on my JGS516PE is not being allocated an IP address by the DHCP server on the subnet
Firmware 2.6.0.48 I am setting up a Vivotek camera and for some reason it does not get allocated an IP address by my DHCP server, after I connect it. If I connect the camera to another POE switch...
- Sep 10, 2023
Thanks for your post.
It turns out the Sophos firewall is dropping the DHCP request packet from the Vivotek camera. Curiously if I set it up with a fixed IP, then change to a DHCP allocated IP, it works! If I then disconnect and reconnect the camera, the firewall again drops the packet.
So there is no issue with the JGS516PE. I have a work around with the D-Link switch, so that will do for now!
Jon
schumaku
Sep 08, 2023Guru - Experienced User
Start with think about the 802.1af PoE - this might not be sufficient.
As you don't give any insight on your Vivotek models, firmware (what works, what does not work), same for that other magic DLink PoE switch, figure....
- JonB16Sep 10, 2023Aspirant
Jon
