philguk2
Feb 21, 2023Aspirant
POE or not POE
I assume no damage will be caused by plugging a device that doesn’t draw POE into a switch POE enabled socket? Thanks
Feb 21, 2023Guru - Experienced User
In theory, correct. You can plug non-poe devices into poe switches. The switches should have an interrogation to it that tells it to send power for the poe devices. that's for active poe switches. The passive one (like injectors) supply power all the time.
