msr86
Mar 24, 2024Tutor
POE+ Switch with VLAN + service/WAN blocking
I am looking to purchase a 8-port POE+ switch with the capability to create port-based VLANs. My only real requirement is that I can create a couple of different VLANs -- one with full network/WAN ac...
msr86
Mar 25, 2024Tutor
I do not need a huge amount of PoE power -- approx. 60W would suffice. 1Gbit port speed is also sufficient.
I'm not really familiar with Spanning Tree Protocol but I am told that I would need a L3 managed switch in order to block one of the VLANs from internet traffic, or to configure this at the router level. I'm pretty limited in my networking knowledge and don't have control over the router so that's not really an option.
Apologies for starting a new thread, I hadn't realised it had been moved to a different topic but happy to resume with this one now.
schumaku
Mar 25, 2024Guru - Experienced User
No worries about Spanning Tree! Just wanted to mention it in this context.
To configure a two (or more) dedicated VLAN, allowing to operate two or more networks and IP subnets independently, a simple L2 Smart Switch with the required configuration support is perfectly fine.
