i0ntempest's avatar
i0ntempest
Port-based QoS/Priortization with MS510TX?
Hi all,
I'm pretty new to this Smart Managed Pro line and kind of got overwhelmed by all the advanced features and jargons. Can anyone please give some info on how to set up port based QoS priority, like in a Smart Managed Plus switch (say GS110EMX which I've had before)?
Thanks in advance.
  • JeraldM's avatar
    JeraldM
    NETGEAR Employee Retired
    i0ntempest,
    Welcome to the community!
    You may refer to this as your reference on how to configure Port-based QoS on the Smart Managed Pro switch. You can specify which ports should be applied under QoS> DiffServ> Advanced >Service Configuration.
    JeraldM
    NETGEAR Community Team
ProSupport for Business
