AaronMcGee
Jun 21, 2018Aspirant
Port Connected to smaller switch shuts off daily
I have a GS750E that has a port that keeps loosing connection on a daily basis. I have turned off power saving mode but it still persists.
- Jun 27, 2018
After a deep cable inspection we found that the security folks while running more camera wires nicked the cable run in question. It still passes certification up to cat 6 but there is noise on the line that we weren't seeing before. We replaced the run and have not had any more issues. Thanks
Carl_z
Jun 21, 2018NETGEAR Expert
Hi AaronMcGee,
Welcome to the community!
There are several things we can check for your trouble.
1.Power saving mode. As you said ,you have disable it, so we can exclude this
2.Loop prevention. If loop prevention is enabled and the switch detects a loop, the switch blocks one of the ports that are partof the loop.
3.Auto DoS. We can try to disable this feature ,then see how things going .
4.The device that connected to GS750E. Suggest to check the device that connected to GS750E and make sure it is working fine.
Can you kindly help to check, and if anything found please keep us informed
Thanks
Carl
Netgear Employee
