AaronMcGee
Jun 21, 2018Aspirant
Port Connected to smaller switch shuts off daily
I have a GS750E that has a port that keeps loosing connection on a daily basis. I have turned off power saving mode but it still persists.
- Jun 27, 2018
After a deep cable inspection we found that the security folks while running more camera wires nicked the cable run in question. It still passes certification up to cat 6 but there is noise on the line that we weren't seeing before. We replaced the run and have not had any more issues. Thanks
AaronMcGee
Jun 22, 2018Aspirant
Thanks for the reply.
1. Disabled
2.Disabled
3. Disabled
4. Brand new gs108 switch. Certified the run to that switch to verify it is fine as well.
That port has gone offline 5 times in the past 24 hours. Either rebooting the switch or just un plugging and re plugging the cable into the port fixes the issue. Have even tried different ports to make sure not just a bad port. Same problem.
AaronMcGee
Jun 25, 2018Aspirant
Any other thoughts on this issue. It has been happening a lot and the end user is not happy.
- Carl_zJun 25, 2018NETGEAR Expert
Hi AaronMcGee,
I also find a GS750E(version 1.0.0.22) on my hand, and have let it run for two days, but cannot see the same issue.
Suggest to open an online case with NETGEAR Support at anytime regarding this concern.They would give you more support. And it best to show they this post,incase they would ask you the same question we have discussed
Thanks
Carl
- AaronMcGeeJun 27, 2018Aspirant
