AaronMcGee
Jun 21, 2018Aspirant
Port Connected to smaller switch shuts off daily
I have a GS750E that has a port that keeps loosing connection on a daily basis. I have turned off power saving mode but it still persists.
- Jun 27, 2018
After a deep cable inspection we found that the security folks while running more camera wires nicked the cable run in question. It still passes certification up to cat 6 but there is noise on the line that we weren't seeing before. We replaced the run and have not had any more issues. Thanks
Carl_z
Jun 25, 2018NETGEAR Expert
Hi AaronMcGee,
I also find a GS750E(version 1.0.0.22) on my hand, and have let it run for two days, but cannot see the same issue.
Suggest to open an online case with NETGEAR Support at anytime regarding this concern.They would give you more support. And it best to show they this post,incase they would ask you the same question we have discussed
Thanks
Carl
AaronMcGee
Jun 27, 2018Aspirant
