marshman
Sep 17, 2018Tutor
Port g19 is a static member and cannot be a candidate in a Voice VLAN 2
Hi. We just picked up a couple of GS752TP 48 port switches we're trying to get setup for both voice and data. When I go into the menus to setup Voice VLAN I get an error message: Port g19 is a static...
- Sep 17, 2018
For any others having this issue, you must remove the ports used for Voice VLAN from the membership of the Voice VLAN. In my case, I had to remove port 19 (and others used for voice) from the membership of VLAN 2. Not just set it as untagged, but altogether removed. No U or T, blank! When the phone is plugged into the port it will automatically change the port to tagged for the Voice VLAN.
marshman
Sep 17, 2018Tutor
JohnC_V
Sep 18, 2018NETGEAR Employee Retired
Hi marshman,
Welcome to our community! :)
Thank you for sharing the solution here in the community! The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
