kslimko
Jan 22, 2021Follower
Printer delay with Port Authentication - GC728X
Firmware version: 1.0.5.25 RADIUS server is a cloud based service where you have an agent installed on managed computers that authenticates you based on user credentials. Unmanaged devices (print...
DaneA
Feb 10, 2021NETGEAR Employee Retired
Welcome to the community! :)
Kindly try to update the firmware of the GC728X switch to the latest version which is v1.0.5.32 then check if the same problem will occur. You can download firmware v1.0.5.32 here.
Hope it helps.
DaneA
NETGEAR Community Team
