fdeutsch's avatar
fdeutsch
ProSafe GS748T doesn't refresh Gateway
Hi all,
I am configuring a GS748T to use our new fiber router.
I changed the default gateway in the IP config options to the new one, the switch uses the new gateway to ping and tracert but connected devices are still using the old gateway, I've tried unplugging our old router and restarting the switch but it didn't change.
Thanks for your help.
  • plemans's avatar
    Do you mean the old devices are still using the IP address of the old gateway?
    Not sure exactly what you're saying here.
    • fdeutsch's avatar
      fdeutsch
      Yes, computers on my network are still exiting the network using the old gateway (xx.1.1) instead of the new fiber one (xx.1.254) even though I changed the gateway address on the switch IP config
      • plemans's avatar
        did you reboot the devices connected and not just the switch/router?
ProSupport for Business
