JeffGPL's avatar
JeffGPL
ProSAFE utility won't accept my new password
I changed the password from the factory default, and the ProSAFE utility would not accept the new password. I did a factory reset on the switch and changed the password again. The ProSAFE utility sti...
  • JohnC_V's avatar
    Jun 15, 2018
    Hi JeffGPL,
    Welcome to our community! :)
    Please try to use the previous version of the ProSAFE Plus Utility. Yes, you can do everything in the web interface and Prosafe Utility is most recommended if you do have a lot of switches inside the network.
ProSupport for Business
