JeffGPL
Jun 14, 2018Aspirant
ProSAFE utility won't accept my new password
I changed the password from the factory default, and the ProSAFE utility would not accept the new password. I did a factory reset on the switch and changed the password again. The ProSAFE utility sti...
- Jun 15, 2018
Hi JeffGPL,
Welcome to our community! :)
Please try to use the previous version of the ProSAFE Plus Utility. Yes, you can do everything in the web interface and Prosafe Utility is most recommended if you do have a lot of switches inside the network.
JohnC_V
Jun 15, 2018NETGEAR Employee Retired
Hi JeffGPL,
JeffGPL
Jun 19, 2018Aspirant
Thank you, JohnCarlo. I only have three switches, so I will probably just stick to the Web interface for now.
Jeffrey Pike
