JeffGPL
Jun 14, 2018Aspirant
ProSAFE utility won't accept my new password
I changed the password from the factory default, and the ProSAFE utility would not accept the new password. I did a factory reset on the switch and changed the password again. The ProSAFE utility sti...
- Jun 15, 2018
Hi JeffGPL,
Welcome to our community! :)
Please try to use the previous version of the ProSAFE Plus Utility. Yes, you can do everything in the web interface and Prosafe Utility is most recommended if you do have a lot of switches inside the network.
schumaku
Jun 17, 2018Guru - Experienced User
Just curious if the "complexity" of the new password chosen could have an impact - special chars, single or double quotation marks, password length, ... Potential password length truncation, whatever. Can't get rid of the impression things are not implemented very consistent, neither on the Switch Web UI nor on the App - as we see this kind of complaints every now and then.
JeffGPL
Jun 19, 2018Aspirant
That's an interesting insight. I don't recall any prompts in the Web interface explaining which characters or what length is allowed in the password. Fotunately, as JohnCarlo mentioned, I can do everything I need to do through the Web interface, so at least for the time being, I will just stick to that.
Jeffrey Pike
