s91066
Jan 28, 2023Aspirant
Questions about GS105PE and pole pass through
Hello, I search for 2 switches to replace my 2 older broken unmanaged TP-Link omes. And I think I will go to the GS108PE and the 105PE. On the 105, I Will connect 3 non-poe devices, 2 laptops and a...
- Jan 29, 2023
Yes, it's fully standard compliant. The only confusion caused is how much power can be made available https://kb.netgear.com/25541/GS105PE-PoE-troubleshooting?article=25541
schumaku
Jan 29, 2023Guru - Experienced User
With the world of IEEE PoE switches like the GS105PE there is no risk of power applied on the PoE ports. An IEEE PD is required requesting PoE power from the power source, otherwise these are just plain Ethernet ports.
s91066
Jan 29, 2023Aspirant
This is something that I know.
However, the specifications are not clear. I copy from the product's page:
- Total PoE Power budget (Watts) : PoE pass-thru: 19W with 802.3at / 7.9W with 802.3af input power.
It doesn't say that the PoE output ports confront with 802.3at/af standard. This is why I ask, effectively I am asking for the experience of other people.
If you say that they are following the standard, then I am happy to "pull the trigger".
- Feb 22, 2022Retired_Member
