s91066
Jan 28, 2023Aspirant
Questions about GS105PE and pole pass through
Hello, I search for 2 switches to replace my 2 older broken unmanaged TP-Link omes. And I think I will go to the GS108PE and the 105PE. On the 105, I Will connect 3 non-poe devices, 2 laptops and a...
- Jan 29, 2023
Yes, it's fully standard compliant. The only confusion caused is how much power can be made available https://kb.netgear.com/25541/GS105PE-PoE-troubleshooting?article=25541
s91066
Jan 29, 2023Aspirant
This is something that I know.
However, the specifications are not clear. I copy from the product's page:
- Total PoE Power budget (Watts) : PoE pass-thru: 19W with 802.3at / 7.9W with 802.3af input power.
It doesn't say that the PoE output ports confront with 802.3at/af standard. This is why I ask, effectively I am asking for the experience of other people.
If you say that they are following the standard, then I am happy to "pull the trigger".
schumaku
Jan 29, 2023Guru - Experienced User
- Feb 22, 2022Retired_Member
