robfantini
May 27, 2018Aspirant
can not change LAG Type to LACP . XS748T ProSAFE 48-Port 10-Gigabit Smart Managed Switch
Hello
I set up LAG7 with ports 7 & 8 as members.
yet at LAG Configuration i can not change LAG Type from Static to LACP.
this error displays: "LAG type cannot be changed for LAG...
- May 28, 2018
Hi robfantini,
Welcome to the community! :)
Your concern is similar to the forum thread below. Kindly access, read and follow the suggestions posted in it.
DaneA
NETGEAR Community Team
DaneA
May 28, 2018NETGEAR Employee Retired
Hi robfantini,
DaneA
robfantini
May 28, 2018Aspirant
OK I'll try that an it'll probably work.
also this is a bug. you know that right?
since 10 other models do not require this work around.
I know you probably do not do the switch low lebvel programming. However others will run in to this - and it should be fixed with a firmware upgrade sometime .
