APDK66
Oct 03, 2015Aspirant
Can't get GS110TP to work as simple as GS105E
For my work I have to check services going over utp links in different vlans. I used a GS105E with its mirror function. I can connect the GS105E without any vlan configuration and all traffic of doze...
- Oct 11, 2015
So I understand I can't use this switch for what I want. I need to check uplinks containing 250+ vlans.
Besides the different configuration effort each time it has a limit of 64 vlans.
I have to look for another solution.
APDK66
Oct 05, 2015Aspirant
APDK66
The trunk carries vlan 4,6 and 7 for different services. Connected with the GS105E it works with default config. Connected with GS110TP with default confifig it doesn't work.
- DaneAOct 06, 2015NETGEAR Employee Retired
Hi APDK66,
Kindly set ports 1 and 2 as tagged (T) ports. What is the behavior and the LED color of ports 1 and 2?
You may use other ports of the GS110TP as trunk ports to isolate the problem. Just make sure to set it as tagged (T) ports.
DaneA
NETGEAR Community Team
- APDK66Oct 06, 2015Aspirant
I did set the ports to trunk on vlan1 the default vlan. That is the only place to set tagged/untagged mode.
Only when I define vlan 4,6 and 7 in the switch it is working when I make the tagged ports a member of those vlans. Without defining vlans the switch just won't forward any frame like the GS105E only untagged frames.
The port connected to the CPE/router is blinking while it sends PADI frames to setup a PPPoE in vlan4. The led of the port connected to the FiberNt is burning green but not blinking.
I think when you want to use this switch you must always define (and know) all the vlans on the trunk and the number must not exceed the 64.- DaneAOct 07, 2015NETGEAR Employee Retired
Hi APDK66,
I would agree that proper VLAN configuration is required on the GS110TP. I conclude that not all switches would work instantly with the given default configuration like the GS105E.Regards,
DaneA
