Steyn-van-Essen's avatar
Jan 15, 2026
CLI support for GS108Tv2?!
Dear Community,   I'm new on this forum but have been using Netgear stuff in a SoHo setting for some 15 years now. First a ReadyNAS RND4000NV, then a WNDR3800 (wifi) router, and then a bunch of GS1...
  • schumaku's avatar
    schumaku
    Jan 20, 2026
    Enter the default username: admin (without being promoted) in the telnet session on 60000, then you will get the password prompt, use the admin password from the Web UI....
    (Broadcom FASTPATH Switching)
    Applying Interface configuration, please wait …
    Like that:
    Applying Interface configuration, please wait …admin
    Password:*********
    (Broadcom FASTPATH Switching) >
    Typing “?” FMI:
    (Broadcom FASTPATH Switching) >?
    enable - Enter into user privilege mode.
    help - Display help for various special keys.
    logout - Exit this session. Any unsaved changes are lost.
    passwd - Change an existing user’s password.
    ping - Send ICMP echo packets to a specified IP address.
    quit - Exit this session. Any unsaved changes are lost.
    show - Display Switch Options and Settings.”
    Even a basic help is available:
    (Broadcom FASTPATH Switching) >help
    HELP:
    Special keys:
    DEL, BS … delete previous character
    Ctrl-A … go to beginning of line
    Ctrl-E … go to end of line
    Ctrl-F … go forward one character
    Ctrl-B … go backward one character
    Ctrl-D … delete current character
    Ctrl-U, X … delete to beginning of line
    Ctrl-K … delete to end of line
    Ctrl-W … delete previous word
    Ctrl-T … transpose previous character
    Ctrl-P … go to previous line in history buffer
    Ctrl-R … rewrites or pastes the line
    Ctrl-N … go to next line in history buffer
    Ctrl-Y … print last deleted character
    Ctrl-Q … enables serial flow
    Ctrl-S … disables serial flow
    Ctrl-Z … return to root command prompt
    Tab, command-line completion
    Exit … go to next lower command prompt
    ? … list choices
    –More-- or (q)uit
    (Broadcom FASTPATH Switching) >”
    Not much more to do and explore beyond that.
ProSupport for Business
