Iwawa's avatar
Iwawa
Apprentice
Nov 17, 2023
About CLI syntax
Hi,
I need supply some GSM4352PA Switches to my customer and since they are also configurable via CLI, the customer's IT manager asks me if the syntax used is the same as that of CISCO.
I contacted the NETGEAR support and was told that they are "CISCO LIKE"; however, despite my insistence, I could not understand if LIKE means "SIMILAR" or "EQUAL."
There is a big difference!!!
Thanks to those who can give me some clarification..
Best Regards
ProSupport for Business
