flattened
Sep 06, 2016Apprentice
WNDAP350 CLI Factory Default syntax
Hi,
Firmware has left me with a cut down 'cloud connect' type GUI.
I need to reset via CLI as suggested by the firmware upgrade notes as the button reset did not restablish the full GUI.
I have tried the suggested restore-configuration /etc/default-config
And an error appears asking for restore host username password
All CLI command lines are prefeixed by netgear70B528 which I assume is 'host' But this fails with bad address.
So I subsituted the default IP address for host. This time it said connection refused (or similar). Is this because I need to enable something via the CLI first?
If so what?
I tried the CLI restore-configuration command and this simply did the same as the button reset.
What do I do?
Andy
Hi flattened,
Kindly answer the questions below:
a. What is the current firmware version of the WNDAP350?
b. Do you want to use the WNDAP350 as a standalone access point? If yes, kindly access the web-GUI of the WNDAP350. Then go to Configuration > Sysytem > Basic > General > Cloud Setting. Then, disable the cloud option and apply the setting.
I look forward to your response.
DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
Hi flattened,
DaneA
- flattenedApprentice
Thankyou - I was so surprised by the loss of functionality I did not even SEE that option until you pointed it out.
All fixed.
Andy
Hi flattened,
I'm glad that its all fixed now. :)
Feel free to post your future concerns here in the community.
Cheers,
DaneA
