flattened
Sep 06, 2016Apprentice
WNDAP350 CLI Factory Default syntax
Hi, Firmware has left me with a cut down 'cloud connect' type GUI. I need to reset via CLI as suggested by the firmware upgrade notes as the button reset did not restablish the full GUI. I have...
- Sep 07, 2016
Hi flattened,
Kindly answer the questions below:
a. What is the current firmware version of the WNDAP350?
b. Do you want to use the WNDAP350 as a standalone access point? If yes, kindly access the web-GUI of the WNDAP350. Then go to Configuration > Sysytem > Basic > General > Cloud Setting. Then, disable the cloud option and apply the setting.
I look forward to your response.
DaneA
NETGEAR Community Team
DaneA
Sep 07, 2016NETGEAR Employee Retired
Hi flattened,
DaneA
- flattenedSep 07, 2016Apprentice
Thankyou - I was so surprised by the loss of functionality I did not even SEE that option until you pointed it out.
All fixed.
Andy
- DaneASep 07, 2016NETGEAR Employee Retired
Hi flattened,
I'm glad that its all fixed now. :)
Feel free to post your future concerns here in the community.
Cheers,
DaneA
