krul876
Aug 22, 2023Aspirant
Re-enabling HTTP from CLI
I was trying to add a management IP to my switch via the Access Control method and I saved the configuration to SSH (which was silly of me). I am now able to connect using Putty to the command line and I'd like to know what commands I should use to re-enable the GUI for my browser without resetting the switch as it's in production. Currently I'm unable to access via the IP address. I'm using a ProSafe GS728TP.
In absence of physical serial console port, and without IP access ...? Figure 8-/
GS728TP is very vague and unclear, the supported commands - for select models - are here Lite CLI Reference Manual Smart Switches.
- krul876Aspirant
I'm not certain what Figure 8 is, but I went through the manual and I'm not seeing an option to disable SSH and enable HTTP. The command
ip http serverdoes not work with this model it seems.
Only these models are supporting the Lite CLI:
GS108Tv3 and GS110TPv3
GS308T and GS310TP
GS724TPv2 and GS724TPP
GS724TPv3 and GS724TPPv3
GS728TPv2, GS728TPPv2, GS752TPv2, and GS752TPP
GS728TPv3, GS728TPPv3, GS752TPv3, and GS752TPPv3
MS510TXM and MS510TXUPIf you had shut your config to the moon (probably on older switch versions), it's time for a factory reset. While there might have been some kind of CLI, it's fully unsupported.
