jmail92
Sep 18, 2025Aspirant
GS308Ev4, GS305E - Help with uplinks/downlinks
Could I please have some help or confirmation that I have these setup correctly? I'm weary that they are because I sometimes have trouble connecting to the admin interfaces on these switches. I've ...
jmail92
Sep 20, 2025Aspirant
Thanks for continuing to reply and try to help. So this guy is wired straight into the Peplink port 4. That guy is configured like this:
Here's the drop down choices:
Port type is only Access or Trunk.
And Peplinks docs say in order to pass multiple vlans, it needs to be trunk. If I set it to trunk, but only chose the UTLAN (Peplink's version of Untagged), would it still pass the traffic of the other 4 vlans? What do think I should do here?
schumaku
Sep 24, 2025Guru - Experienced User
This is an unnecessary feature limitation by Peplink. Very common in the networking industry to operate a trunk (multiple VLAN) together with an untagged access port.
However, in an earlier reply you showed a custom configuration for that port with one untagged and some tagged. So there is no limitation.
