Chela
Sep 01, 2015Aspirant
Setup Help pls - GS728TP with Billion Router 7800VDOX
I need some help setting up my Netgear GS728TP managed switch with a Billion Modem/Router BiPac 7800VDOX I have tried to set up straight out of the box with factory defaults but everything seems ...
- Sep 03, 2015
Hi Chela,
Chela wrote:
c. All the LEDs kind of seem to blink at the same time roughly.
Kindly observe if the Link/Act port LEDs if its blinking green or blinking yellow. Please refer to the Port LED Designation on page 14 of the Hardware Installation Guide for the GS728TP here.
Chela wrote:
e. I haven't run any specific speed tests, I noticed a noticable drop in browser and download speeds after the GS728TP was added.
You may isolate the problem by running a speed test on a PC. First, while the GS728TP is connected to the Billion Router 7800VDOX, run a speed test on a PC that is hardwired to the GS728TP. Second, run a speed test on a PC that is directly connected to the Billion Router 7800VDOX. Compare the results.
DaneA
Netgear Community Team
Chela
Sep 07, 2015Aspirant
Thanks DaneA,
C. I've had a look at the Port LED Designation page which provided a few clues that have led me to dig a bit deeper. As a result I have found that some of the cables are reported as "Shorted". I will look into all the cables and rectify where needed.
E. I did the speed tests as you recommended but the speed did't improve or degrade either way - keeping in mind the point above, I will do the speed tests again after I look into the cables and confirm they are wired correctly.
I will let you know how I go.
Many Thanks :-)
Chela
Sep 09, 2015Aspirant
Hi DaneA,
I've now checked the network cables and tidied them up, had a few that were loose and I've re-terminated them.
I'm happy to say it now runs significantly faster and without the occassional delays I had previously.
Many thnaks for your help :-)
Regards
Chela
