drsox
Feb 12, 2022Guide
Switch Discovery Tool Unable to Detect following
I redownloaded the Switch discovery tool (this time it's the .103 version. It detected none of my 3 GS108tv2 switches. The last version worked fine ( .102 ). The switches are OK as I can detec...
DaneA
Feb 16, 2022NETGEAR Employee Retired
Firmware on all switches is listed as : 5.4.2.33.
Let us try to update the firmware of the GS108Tv2 switches to the latest version which is v5.4.2.36 then observe if the same problem will occur.
You can download GS108Tv2 firmware v5.4.2.36 here.
DaneA
NETGEAR Community Team
drsox
Feb 16, 2022Guide
Thanks but that doesn't solve the problem.
To upgrade the switch firmware I need to run the Smart Control Centre. This only runs in Windows. I no longer have any capability to run Windows.
