gdlgiii
Jan 01, 2018Tutor
Update home network for IoT and private devices
Using a Netgear R8000 Nighthawk router, I would like to connect 2 GS108Tv2 switches to support 2 VLANs. I want to separate the computers, phones, tablets from the Arlo Cameras, Google Home, Chromecas...
- Jan 01, 2018You should set the default VLAN for an untagged port to the VLAN that you want untagged traffic received on that port to be mapped to. So that means the default VLAN for the ports connected to the HTPC, PC, NAS and RPi3 should be set to the private VLAN. And the ports for your IoT devices should have their default VLAN set to the IoT VLAN.
TheEther
Jan 01, 2018Guru
There are a few discrepancies in your post and your diagram. The post talks about unmanaged switches but the GS108Tv2 is a managed switch. The diagram shows the RN104 on a trunk link, but it's labeled as Private VLAN, so the link color should probably be maroon.
Anyway, the general layout of the diagram looks ok. The problem is that the R8000 doesn't really support VLANs. This means that not only can you not use a trunk link from it to the GS108T, but the VLAN isolation in the rest of the network is going to be undone by the R8000.
You really need a VLAN capable router to pull this off. You can load third-party firmware, like DD-WRT or Tomato, onto the R8000. Or get a SOHO/business class router. Netgear has their line of UTM and VPN firewalls, although you should look at other brands.
Port forwarding will still be done by the router.
gdlgiii
Jan 01, 2018Tutor
So, if I obtain an Ubiquiti EdgeRouter Lite, I could possibly do this? Thinking of devices that are not VLAN aware, perhaps it would be best to set the default vlan to the new IoT (vlan50) vlan on untagged ports?
I sent an different layout. I don't think I will have funds to purchase the netgear AP and will need to repurpose netgear routers.I have 1 R8000 and 2 R7000 routers I could use as APs for their respected vlan I would think.
- TheEtherJan 01, 2018Guru
Yes, an Edgerouter Lite would work. I have one and it's great.
What are you trying to accomplish with this?
Looks like your new layout just has the R8000 swapped out with an Edgerouter, but it still shows the WAC730. Anyway, you can certainly use the R8000 and R7000 as APs and place each one in a different VLAN.
- gdlgiiiJan 01, 2018Tutor
I forgot to remove the WAC730 AP from the diagram. My goal for this is to separate private network traffic from IoT traffic while repurposing some existing hardware. I am trying to keep it somewhat simple while keeping a secure environment.
- TheEtherJan 01, 2018GuruI understand, but I don't know what's your rationale about setting untagged ports to default to the IoT VLAN?
